  1. I created subtitles with SubRip. When I try to import srt file into the project, everything is OK. Then I try to generate subtitle stream and have "Abnormal program termination error". I tried it twice with different files - the same problem.
    Does someone had the same problem?
    Apr 2004
    Miskatonic U
    Which version ?
    Have you updated to the latest version ?
    Have you checked the official mediachance DVD Lab Pro forums ?
    Read my blog here.
  3. Dvdlab Pro 1.0. I believe, it's latest.
    No, I didn't visit mediachance forums. But I guess, there's nothing wrong with srt files. They worked before. I try to reinstall the version.
