If I capture MPEG-2, here is a screen shot of ReStream shows:
I do not really know what much of the stuff means, but when I play back the file on a computer, it plays it back as a progressive image.
The problem is, there are interlace lines. They are in the normal 3Progressive, 2 Interlaced pattern.
Can I just tick some of these flags to turn my MPEG-2 into an interlaced one, and would it be DVD compliant?
What are you tring to do? Are you going to play this on the computer or Burn it to DVD to play on the the TV?
computer primarily, possibly a TV once in a while...
I think that if I just change both the Progressive flag, and Progressive sequence to interlaced then the software players will deinterlace it, and a standalone passing to a TV will just pass the already interlace signal (even though it is encoded as progressive)...
I was just wondering if this is right and if it would be DVD compliant...
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
