No mds files?
What We Do In Life, Echoes In Eternity....
The .mdf file just contains metadata about the iso. Its sort of like the .cue to a .bin, but not as important. You need it mainly for split images (your image is 8 gigs but you run Fat filesystem so it splits it into 4 gig chunks and burns the whole thing to one DL disk) but its also a good idea to use it for DL burning in general. Unless you are doing either of these two things, you likely won't miss the .mdf files.
DVD Decrypter can create a mds from an iso. Not needed if using Shrink, as it can open an iso w/o a mds.
The ISO files are all from dvd+r(4.37gb) so am I ok? Will they burn and then play fine when I go to but them on dvdr? I want to transfer them to MCC003 dvds from the Prodisc R03 they are currently on.
What We Do In Life, Echoes In Eternity.... -
phew.....thanks for all your help....
Creating MDS file automatically When ripping to ISO With ImgBurn
By bbanderic in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 21:53 -
Are DVD-R/DL (double layer MINUS R) incompatible with ISO/MDS for +R/DL?
By miamicanes in forum DVD RippingReplies: 16Last Post: 31st Dec 2009, 21:24 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 13th Aug 2009, 23:36 -
DVD Shrink .ISO/.MDS issues...
By AGenius in forum DVD RippingReplies: 6Last Post: 19th Mar 2008, 12:53 -
dvd iso/files burning problems
By CommanderZero in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 01:25
