Im having trouble converting avi to vcd. I used the tmpgenc
to changed from avi to mpeg then when i went to burn it to vcd using Nero 5.5.5.1 it prompted to encode again. Im stuck on this one. Any help would be appreciated on this conversion.
shep
It looks like your MPG file is not VCD compliant. Did you use the VCD template provided? If yes, did you make any changes to it prior to encoding?
It should work. -
I get that from Nero once in awhile. If you did use a standard template in tmp, just turn off standard compliance when Nero prompts you and burn as is. It should work.
Liz
Lots of Trouble Converting FLV to AVI
By elykl335 in forum Video ConversionReplies: 5Last Post: 27th Feb 2012, 15:06 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 15:42 -
Trouble converting avi to dvd
By illyad in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 08:34 -
Trouble converting m2ts to either WMV or AVI using SUPER
By Royksoap in forum Video ConversionReplies: 1Last Post: 31st Jul 2009, 13:54 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 18:21
