i had extracted a dvd contect to VOB files in a folder. how do i convert these VOB files to VCD format so that I could watch the content using a VCD player?
thanks.
percy
Results 1 to 11 of 11
Percy
i have downloaded the file but does not have a setup file to install it. pls. help. ty.
Percy -
when i opened eht DVD root (where the VOB files are located), it had an error " auth.dll: Can't authenticate drive Disk may be not locked"
what's wrong?Percy -
i was able to extract the dvd to an mpeg file but the size is 1.5Gb... how can it fit my 650-750Mb cdr? how do i reduce the size without splitting the file so that 1 file is 1 disc for a VCD?
it also extracted 2 vob files, 1 is 4Gb is size and 1.8Gb.
thanks.Percy -
VCD is fixed bit rate 1150 kbps, so for a given movie length, you'll get a fixed file size. You must split a too long movie over several VCD. (Some might argue that 1150 is max allowed bit rate for VCD, but honestly, quality will suffer horribly if you go lower.)
/Mats -
If you are using EazyVCD still, try this guide. if you want to do it the manual way, I suggest you search the guides section, or try this guide.
If in doubt, Google it.
Does mono save space?
By Eddie the Editor in forum Authoring (DVD)Replies: 15Last Post: 30th Jul 2011, 11:47 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Edit VOB files and save to dvd
By NickyJ in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2008, 12:59 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Converting Youtube videos to view/save files
By medemt in forum Video ConversionReplies: 1Last Post: 4th Apr 2008, 10:37
