I have just copied a few of my old videos onto DVD-R format using a Lite-on Allwrite LVW-5005 recorder. It replays fine on this machine even after it has been finallised.
However, when I go to play it on my stand alone JVC XV-S332 player it does not play any sound. The picture works fine, just no sound.
Some other DVD-Rs authored on a PC work fine in this player so I don't think that is the problem of not being able to play DVD-R.
Another related question - these need to be edited further on PC to tighten scene changes and make half decent menus. I am wondering what sound settings/format should I give the video to make it readily compatiable with all DVD players (that will play burnt discs)
Is the audio MPEG audio? That's not compatible with all DVD players.Originally Posted by Raynman
Use AC3 if you can or PCM if you don't have AC3 compatible editing/authoring software. Nothing wrong with PCM but it takes up a lot of space.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
