  1. Wanting to gain a bit more knowledge about my system, I searced the forums and read up on the ADVC-50 and found out a few bits (such as the Macrovision tweak) but more importantly, came across the link to the Panasonic codec which would allow a Canopus caputured AVI to be imported into Virtualdubmod.
    Having read many people putting in a good word for Virtualdub/Virtualdubmod, but only having used it to get screen caps from VCD or DVD MPEG files, I wanted to try this as an editor. I downloaded the codec, installed it and indeed was able to import an AVI, into Virtualdubmod, captured using the ADVC 50.
    I was particularly interested to be able to Frameserve to TEMPGEnc rather than save a new AVI for any AVIs that require some editing.
    So to the guides I looked: https://www.videohelp.com/virtualdubframeserve.htm
    So far so good.
    Followed the instructions: installed the Flameclient support, rebooted PC, imported AVI, edited it and then through to the Frameserve.
    Start Frameserver > Framerserver Set Up > File Name "video.vdr.avi" > went into Frameserver mode (below)
    At this point, it stops - all figures remain at zero, no indication that it is doing anything at all and stays like that for quite a while. In the end I click the 'Stop Serving' button (probably out of impatience).
    From the search that I have done, the only clue I have is that there may be issues with XP, so can anyone advise what may be going wrong.
    I suppose I could just save to a new AVI, but if the Frameserve ability is available, then it would be a pity if I couldn't use it.
    This is happening in XP, P4 2.8, 1.25gb memory.
    Thanks in advance.
    Cole
  2. Of course it's going to stop. You didn't tell it where (what program) to frameserve TO! j/k
    Open tmpgenc, select the "Capture05.vdr.avi that is created, start your encoding.
    Tmpgenc will get the edited file directly from vdub, without you saving an interim avi.
    Cheers, Jim
    My DVDLab Guides
  3. Okay, thanks for that - so at the point where I have the Frameserver mode open, I then open TEMPGEnc and open said file.
    I have just re-read the guide and now understand that, but I didn't pick up on this first time
    Thanks for the push in the right direction.
    EDIT: Had a test and this works perfectly.
    Cole
  4. Heh, no worries. We all get befuddled at times.
    Cheers, Jim
    My DVDLab Guides
