...has expired, and I'm in dire need to use it - since I'll be away for three days, I'd love to launch a batch conversion before leaving.
There's no trace of version 2.02 on the official site, is there any way to bypass the 30-days limit?
Thanks in advance,
Ed
Results 1 to 9 of 9
You can't bypass the problem. But you can do that:
Delete the entire folder where you run tmpgenc from and then create the folder again, open the tmpgenc.zip file, extract at the folder you created and you will have 30 more days for MPEG-2 use. -
you can by pass the problem, you just know how to you use the SEARCH feature of this website as this quesiton easily gets asked once a week
Thanks. And to Kdiddy: sorry, I searched, but I probably used the wrong keywords.
go to the page of this forum dated 2001-11-20 with the question titled "mpeg2 trial period has ended.
To reset the 30 day trial period for TMPGEnc delete this key in the registry;
[-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
should have done your reaserch!!!
https://www.videohelp.com/phpBB/viewtopic.php?topic=59167&forum=3
What browser are you using these days?
By johns0 in forum PollsReplies: 60Last Post: 28th Aug 2012, 21:30 -
MPEG Streamclip "limit data rate" disabled
By Dignan. in forum Video ConversionReplies: 7Last Post: 23rd Nov 2011, 13:59 -
Remove 4032mb Limit On TMPGENC 4.0.
By Anakin in forum Video ConversionReplies: 1Last Post: 28th Sep 2008, 19:41 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30 -
The PC's last days?
By Jo The Veteran in forum ComputerReplies: 8Last Post: 11th Sep 2007, 08:44
