    I want to do an encoder test and capture some screenshots. My source will be interlaced dv and my output will be interlaced mpeg2 for dvd. What is the best freeware program to capture screenshots to compare mpeg encoders.
  2. Member jlietz's Avatar
    Illinois, USA
    I don't know about best, but I use Media Player Classic. There is an option under the File menu to "Save image". I think it saves as JPEG.
  3. There are two that I have used:
    Virtualdubmod and imagegrab but the latter is only for VCD and SVCD.
    Hope that this helps.
    Cole
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    VirtualDubMod to copy and paste into an image editing program of your choice.
    - John "FulciLives" Coleman
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    i use virtualdubmod - but you can use media player classic ..
    virtualdubmod is better for compare purposes - because you can see if you are capturing a I or B or P frame
