I am trying to transfer my Hi8 and Digital 8 video's onto my PC so I can burn a dvd. I have a Sony Camcorder which uses a DV in/out to the PC ilink input. (firewire) I don't have this cable and I don't think my PC has a ilink input slot. I tried the usb camcorder to PC hook up but the pc did not see the camera. What do I need to do?
Results 1 to 10 of 10
Buy a firewire cable for about $20.00 and IEEE card for your compute for about $15.00 and install it. For less than $50.00 you'll be good to go.
Mark -
get a 15$ firewire card and cable
Ok I will purchase a cable and card. Are they all the same? Since I have a Sony Camcorder do I need to purchase the cable from them? Can I purchase a firewire card or do I need a i link card since I am using a Sony product? I will check the local PC shop but usually the net beats the price by a lot. Can you recommend a software program to convert the videos to dvd. Just the basic's add a menu, titles edit out some stuff. Nothing hi tec is needed. Thanks again for your input.
I-link(Sony), firewire(Apple) and 1394(Generic...just the name) are all the same except the name. You may have this port on your computer, do a google image search for it. You'r probably going to need a 4pin to 6pin cable.
For starters you can try Ulead Video Studio, it's fairly easy to use, lot of options, decent quality and it isn't going to set you back a whole lot. -
Originally Posted by thecoalman
http://images.google.com/images?hl=en&lr=&safe=off&q=firewire
The larger ones are 6 pin which would probably be the one on your computer but doesn't have to be. The smaller ones that look smilar to a small USB but with a notch are 4-pin and is the one that would be on your cam.
If you have a Audigy soundcard there will be one on there. You can use it but I had trouble using it on my coputer but others have had success. It was just a particular issue with my system.
Edit:Before you go poking around in the back go to start>control panel>system>hardware>device manager and look to see if IEEE 1394 is listed under the devices. If it isn't you need to purchase a card. If it is listed then look to see if there's a external port. Note:just because it listed under device manager doesn't mean that you have a external port you can plug your cam in. -
Thanks again. One last question can I purchase any firewire card? Do I need all of the specs from my pc prior to purchase?
most any will work - some better than others .
the ads ones are good and not expensive"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Anyone PCI firewire card will do, you only need a open PCI slot to install it to. Which if your machine is a stock Dell there should be one. The card should come with install instructions but it's really just a matter of opening the case up and plugging it in. Pretty simple.
See the edit on my above post.
Sony HC3 firewire port dead,cheap miniDV camcorder to use for transfer?
By alegator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 76Last Post: 13th Jul 2011, 19:59 -
Want to transfer video but no Firewire port on laptop!!! Aagh! Please help!
By colinb1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Apr 2011, 12:08 -
How can I capture video with no firewire port?
By dickieb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 22nd Apr 2011, 16:05 -
help regarding importing footage from camcorder to pc through i-link port
By sumit singh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Feb 2011, 13:54 -
Expensive or cheap iLink/Firewire cable for video transfer?
By chin569 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Jun 2008, 11:37
