Im trying to back up a dvd of mines and i tried everything from DVD Decrpyter and DVD Shrink and ISO buster, VoBBlanker, and they all failed i checked the disc and it was ok. any advice here would be appreciated. thankx
Try the latest version of DVD Decryter (2.5.20 or something like that). If that doesn't work...most like a bad disc or a new movie like RE2.
Google is your Friend -
Download and install the newest version of AnyDVD and keep it running while you rip the movie with DVD Shrink. I got the same problem backing up my copy of Resident Evil:Apocalypse and that solved it. If that isn't it, could be scratched or just a bad disc.
Thanks fallenflame. I had the same problem with RE2. I used AnyDvd with DVD Shrink and it worked like a charm. Only problem is, anydvd is not a freeware program. After 30 days it will cost $40 to keep. Any freeware that you know of, that will accomplish the same thing?
Thanks -
its a movie called "Living Hell" been trying to back this dvd up for awhile and noting seems to work i also cleans the disc and still hasnt worked
any suggetions?
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 02:32 -
DVD Lab Pro 2.20 ERROR. Check inside!
By nick_gr in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2010, 09:54 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 22:35 -
data redundancy?
By beer31 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 01:32 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 03:31
