Hello,
I am using already a few years the TMPGEnc software to edit/cut my MPEG1 files I recorded via my Dazzle DVC USB from video or television. So far it went successfully on my laptop under Windows 2000.
However, recently I switched to a new laptop under Windows XP, installed the same software, but ran into two problems :
1. Everytime I edit the raw file with FILE – MPEG-TOOLS – MERGE & CUT ; I get a error-message :”At address 3555822D , Read Error occurred against address 3555822D” .
2. Whenever I want to edit the size of the generated VCD-file (to fit it on one CD) with changing the average bitrate (in TMPGEnc templates, as well as KWAG’s ones), the generated file is exactly as large as the original one !
This happens with TMPGEnc version 2.51.33.127, core version 1.82.121. Also newer versions give exactly the same problems.
Who can give light in this darkness ?
Kees Bal
The Netherlands
Results 1 to 1 of 1
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 01:59 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
