I generated a MPEG 2 file (chose defaults in TMPGEnc) from an AVI file. At a certain point the index is messed up so I can't place chapters where I want.
I have observed this in Nero Showtime, but happens in other players as well.
The beginning and end of this one hour MPEG clip seem fine, however, somewhere in the middle if I move forward to a position by typing in a time (say 27 mins) I get playback starting at a certain scene. If I play for about 5 minutes (now the file is past the problem area) and type in 27 minutes I get playback from a difference position. The position is not random - if I am moving forward to the problem area I get the same scene, if I am moving backward to the problem area I get the same scene - but I don't get the same scene for moving forward and backward.
There seems to 5 minutes or so that is indexed differently depending on which direction I am moving across the file.
This causes problems when Nero Vision tries to assign chapters.
I thought maybe there was a problem with the AVI - AVICodec said that the code was unknown so I recapture and AVI type 2 file and re-encoded to MPEG - I had the same problem.
It this a problem with the encoder or am I doing something wrong?
I forgot to mention that I used the latest version Scenalyzer (not beta) to capture the AVI.
OK, so three seconds after I post, I snoop the forum for other converters and decide to give The FilmMachine 1.4 a try. When it trys to open the AVI it complains "List index out of bounds(3)"
Would this cause the MPEG indexing problem or is FilmMachine mistaken (this version of FilmMachine is refusing to calculate a bitrate - so I don't know if the software is solid)?
I used a stop timer in scenalyzer - does Scenalyzer have any known issues?
Is there software for checking the integrity of AVI and/or MPEG files? I searched high and low and could not find any.
Thanks,
D.
DVD Shrink generates different files even with the same settings
By sldvd in forum Newbie / General discussionsReplies: 7Last Post: 20th May 2010, 17:19 -
Muxman generates a corrupt VOB. What now?
By Asterra in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2010, 00:00 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Muxman generates a dvd with only single chapter??!!
By StarX in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2009, 04:24 -
Thoughts on Tmpgenc Express 3.1.5.82 Trial
By Batfink in forum Video ConversionReplies: 15Last Post: 30th Oct 2007, 01:17
