As some of you know I upgraded from the Hauppauge 150 to the 250 because I was having sound issues.
The 250 working well. No audio issues. I have a couple of 5.1 cards lying around and I'm curious.
1. But... can I use a different audio source for capturing? My gut says no, because onboard of sync issues.
How hard is it to capture video through audio line in and resync later? Any steps (and tools) would be appreciated.
Since the PVR-250 encodes both the audio and video on-board you can't have it use an external audio card.
In theory you could capture audio via another program while capturing video with the PVR-250 and then mix the two later.
But it's doubtful your 5.1 audio cards can capture 5.1 audio. They probably just play 5.1 audio. -
AC3 Plugin and AC3 Filter
Does your sound card have Optical Inputs/Outputs in the rear?
You could capture the sound through software.
Still a WinTV PvR-150 fan here, no audio problems for me!Best Regards,
Tipstir
MediaMVP Supporter
discrete sound card vs onboard quality
By mammo1789 in forum AudioReplies: 1Last Post: 17th Dec 2011, 08:53 -
Disadvantages of motherboards with onboard graphics?
By A Traveller in forum ComputerReplies: 2Last Post: 13th Jun 2011, 15:12 -
Panasonic GS-250 taped race has area of no picture but sound
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2010, 05:32 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Onboard encoding or not?
By NES_Master in forum Capturing and VCRReplies: 3Last Post: 5th Jun 2007, 19:59
