  1. Please help. Thanks in advance.
    Apr 2004
    Miskatonic U
    of what ?
    Read my blog here.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by guns1inger
    of what ?
    What he said.
    If in doubt, Google it.
  4. How do I change the title, author, description, etc. OF a video. You know, AVIs and OGMs.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Is it on the video itself like a graphic title?? Or are you talking about the actual file name you see on the computer????
    If it's on the video you may be out of luck. Or you could use virtualdubmod and delogo to remove them but you'll see watery aftereffects.
    If it's on the computer simply right click (windows) and select rename. Right click and choose properties to edit more information.
    More detail would help us to help you.
    Kevin
  6. I don't know what is it on. I used GSpot to identify the file, and I see author, discription, etc. But when I go to Properties of a file, it does not show.
  7. No, I'm from Iowa. I only work in outer space.
