I've been burning DVDs with Nero Express 6 (Nero OEM & NeroVision Express 2) however I'm getting frustrated with the menu authoring options.
I'm wanting to burn a disc that has about 6 different "episodes", I'd prefer the links to be just text, but for some reason Nero will only let me create a menu with various picture links. These are annoying considering the background I wish to use.
Can I use a different menu creation programme ?
If so, what would you recommend and how could I import it ?
~*Love it or shove it*~
*~I don't know the solution, but I admire the problem~* -
One thing that I've discovered with Nero is that you can click and drag all of the picture links to a location of your choice, so they aren't sitting right on top of a part of the background that you want to be able to see. Never tried to get rid of the the picture, though.
Help with iDVD menu options
By HowardNeedsHelp in forum MacReplies: 0Last Post: 27th Aug 2009, 21:50 -
Vista compatible disc authoring/burning software with sub menu options?
By wetcamelfood in forum Authoring (DVD)Replies: 7Last Post: 7th Jan 2009, 22:08 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
DVD Menu Options
By BritGuy79 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2008, 17:47 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 08:00
