Hello,
I've used TMPGEnc before and I've successfully encoded 4 movies with it. During the search for this excellent program, I downloaded a total of about 15 different shareware etc avi->dvd programs, and found them all to be rubbish. Finally I found TMPGEnc, so I just used it to convert my movies.
Now I've got enough time to clean up my system, so I uninstalled all of those programs and any extra codecs I had and started from scratch with just a few good programs that I found. However, now when I try and encode a movie with TMPGEnc, it doesn't work.
I believe I'm missing a codec, the file I'm trying to encode is in DivX, and I've installed the 3.11 alpha and 5.21 codec releases.
What it does when I try and encode the movie, I set it so the output size should be roughly 3.7 gigs, and start it going (using default PAL DVD template settings). The output that is produced, however, is roughly 170-180 megs in size and is black when I try and play it. Also the preview window in TMPGEnc is completely black and never shows any image, whereas before it did.
Has anyone encountered this problem before, and if so, what did you do to solve it? As I said, I think it's probably a codec problem, but apart from installing both 3.11 and 5.21 of DivX, I don't know what to do next.
	um, i had that problem too once upone atime, does it do this with other divx files if so , you prob got an xvid codec installed & configured to play div x too. i think???? try it! disable it so that you play divx with the divx codec i think
	xvid decodes divx no problem. That's not the source of his problems. Sorry, I had to go see about a girl
	Found the problem.
 I looked under the Environment settings and VFAPI plug-in and I found it said "The file cannot be loaded" for DGVfapi.vfp. So I searched my computer and found that GordionKnot comes with a copy of this file, so I copied it into the TMPGEnc directory and it fixed it.
	Exactly! Good job Lanthanide! La Linea by Osvaldo Cavandoli
  Probably a dumb burning questionBy neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 05:34
  Dumb PS3 QuestionBy wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 08:56
  Really dumb USB 1.1 QuestionBy ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 16:50
  dumb test onlyBy bendixG15 in forum TestReplies: 2Last Post: 19th Dec 2008, 14:48
  Dumb question about 768pBy winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 17:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
