Hello.
I followed some tips i got, and used vcd gui to make bin and cue
files out of mpegs i had.
but, when i tried to move the files onto the tracks, it wouldnt
work,
why?
Because it didnt reconize them as mpegs! (I used Nero 5.2.2.4)
What should i do?
Use another cd burner software?
If anyone can help me, i would be very happy..
ps! Has any other here had this problem before?
In Nero you open --->file --> burn image
You choose the cue file which will direct the program automatically to the bin file.
After that - you just burn.
Also make sure you click "all files" otherwise the cue file will not show up. One other tip. Don't move your bin files around. The cue file contains a specic location as to where the bin file was originally created. If you've moved your bins around you must move them back or simply edit your cue file to the new location.
Sony Vegas 9.0 - mass fade-out and moving tracks
By Ygramul in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2010, 12:33 -
problems making dvd from vob files only
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:20 -
Problems making video_TS files with fmpegX
By skorn in forum ffmpegX general discussionReplies: 2Last Post: 31st Mar 2009, 20:31 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
