For those thinking about getting this card, well for me I have no problems with it. I know a few others who also share the same. Some here are having problems with the audio level being to high. I haven't run into that problem. The CAP card is mostly used to capture CATV shows and display them on my TV using the Media MVP 1000. Dubbing from a Hi 8 Cam to the inputs on the rear, I still don't have any problems either way.
WinTV PVR-150 with 45 button remote
http://www.circuitcity.com/ccd/productDetailReview.do?oid=99358&com.broadvision.sessio...cfkmdffhdffg.0
10-bit video processor
Single chip design for audio and video
MPEG1/2 Hardware Encoder
MPEG1/2 Software Decoder (included, but optional where you can use any)
Stereo dbx
GB-PVR www.gbpvr.com
Turns any PC into HTPC (home theater personal computer)
Uses the WinTV PVR-150 to record, watch, view CATV onto your PC
Run the GB-PVR Server to connect the PC to Media MVP 1000 to watch all the media on your PC to your TV. More than one MVP can be connect to each TV in your dwelling well up to 12.
Media MVP 1000
http://www.htpcnews.com/main.php?id=mediamvp1
Watch, listen to everything on your PC onto your TV
Pictures, Movies, Music, Web Radio
Results 1 to 1 of 1
Best Regards,
Tipstir
MediaMVP Supporter
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05
