Results 1 to 11 of 11
Please click the link. Basically, it says my divx decoder is not registered - twice....
Depends if you want it registered or not. I would get rid of the intervideo MPEG4 decoder though. Then if you want DivX try manually registering the filter or uninstall/re-install.
What is "registering" and why remove the intervideo mpeg4?Originally Posted by celtic_druid
registering is proper installation so that windows will recognize the codec.
Google is your Friend -
What is registering?
Codec not registered. Solution register it.
regsvr32.exe /u mp4dec.ax (unregisters it)
regsvr32.exe divxdec.ax (registered it)
There are I believe two copies of mp4dec.ax though.
Why remove intervideo? Because I don't like it. It causes problems and I think it is based on DivX anyway (definatly handles the same fourCC's), so you wouldn't need both. -
@ loopyloops - Slightly off topic, sorry. But I've a friend who may be having trouble with codecs, and a tool such as you're using might be useful.
Which one is it? Thanks...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks both...
Carpe diem.
Animation attached to multiple slides
By siebr001 in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2010, 06:40 -
Network Attached Storage
By igeekus in forum Media Center PC / MediaCentersReplies: 1Last Post: 31st Aug 2009, 14:58 -
Is this normal to get this (pix attached) while using VLC?
By tigerb in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2009, 13:16 -
Trying to open a port (pic attached)
By Rudyard in forum ComputerReplies: 9Last Post: 6th Mar 2009, 18:08 -
New / problem with codecs
By AJ Martinez in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2007, 20:32
