Results 1 to 17 of 17
sounds like a problem with the recordings. I'm not familiar with that software. Computer possibly isn't fast enough to keep up with the quality settings you are using. Try some sample recordings at different resolutions/quality settings and see if the audio is still out of sync.
Google is your Friend -
Just had a similar problem. Different software, but same problem.
https://www.videohelp.com/forum/viewtopic.php?t=251368
I found out it doesn't happen with ALL of my video files. And I stumbled onto something while loading a file into VirtualDub. It gave me an error stating that the audio was VBR and it would change it to CBR, but this may cause out of sync.......... or something like that. And that error only comes up on certain movies I have. So I think that may be the problem. CBR vs. VBR.....or VBR vs. CBR. Just a guess.
How fast does you comp. need to be to work with quality settings? And why was my comp. fast enough a few days ago? Look, my comp. has some legacy parts - xp3000+, 5950 ultra video card, audigy 2 - non zs, but it's also got 2 raptors in raid-o, a gb of xms memory...Originally Posted by Krispy Kritter
Below is a link to a thread in which I discuss the method I use to re-sync audio and video. Good Luck.Originally Posted by loopyloops
https://www.videohelp.com/forum/viewtopic.php?t=251014&highlight= -
Thanks - will check it out right awayOriginally Posted by rkr1958
I'd have to do what you suggest each time I want a usable mpeg2, no? I'd love to fix the problem - wonder how it got messed up?Originally Posted by rkr1958
Well ... sometimes the problem is with the audio capture rate. For example, I've set the audio capture rate to 48000 Hz in VirtualVCR. The actual rate turned out to be 47993 Hz due to some error I don't know. However, a player thinks that the rate is 48000 Hz and will play it at that rate. The result of this is that after an hour the audio will be ahead of the video by over 0.5-seconds.
To see it another way, at 48000 Hz and after an hour the audio will have played 48000 Hz * 3600-seconds = 172800000 samples. But since the actual capture rate was 47993 Hz, the audio should have only played 172774800 samples. Thus, the audio is 172800000-172774800 = 25200 samples, or 25200/47993 = 0.525-seconds, ahead of where it should be.
If you're having a similar problem ... there may be not easy fix to correcting this error at capture ... however, the timewrap function in Goldwave will correct the error after capture ... good luck. -
Thanks! Does this tell us anything?:
[1/11/2005 21:50:07] Setting MPEG-2 constant video bitrate to: 4000000
[1/11/2005 21:50:07] Setting MPEG-2 audio sampling rate to: 48000 Hz
[1/11/2005 21:50:07] Setting MPEG-2 audio bitrate to: 224000
[1/11/2005 21:50:07] Setting MPEG-2 stream type to MPEG2 DVD Stream -
Its not the setting values that you need but the actual audio sampling rate. For example, VirtualVCR produces a capture log that give the actual audio rate, which is slightly off fro the setting. -
Ok, the mpegs I'm recording with BTV are pulsating, i.e. 3 secs or so fine then a very brief pause with total regularity - now using an aiw, btw. Thoughts?
Also, it's like this in any player or burned to DVD...This is especially niticable when zooming or panning is going on.... -
soudns like there's an I/O bottleneck somewhere or ther's not enough buffering to memory. try also capturing raw as encoding to MPEG2 while reeciving a stream is VERRRY I/O intensive.Originally Posted by loopyloops
Thanks - I have no choice how I capture - only compression degrees of mpeg2. Just tested the ati pvr software and it doesn't do it with that - so it must be a btv problem - what, I wonder?Originally Posted by funkguy4
bump
You are in breach of the forum rules and are being issued with a formal warning. PLEASE wait a few days before you bump.
/ Moderator Baldrick -
Turns out it's the new BTV encoder and Athlon Procs.Originally Posted by loopyloops
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 08:53 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 08:51 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 01:59 -
After downmix audio video sync problem
By adarkenigma in forum Video ConversionReplies: 7Last Post: 17th Oct 2007, 10:10 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 05:27
