Ok, i have a file i am converting to m2v from avi and i was setting all the options in tmpgenc plus! whem i realised this odd aspect ratio. I am a newb to encoding and have not ever run into this before. So, my question is what should i set the source aspect ratio and the converted aspect ratio as?
Idunno but here's a great guide on it ... https://www.videohelp.com/forum/userguides/174200.php
1) Give us a screen cap of your source file so we can see what it should look like.
2) Describe what it is you are trying to do. In proper English, preferably."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
I apologize but, what exactly is a "screen cap"?
Edit: I figured out the aspect ratio using the guide. I thank you both for the assistance. -
Hello,
Just to let you know here are two of the most common ratios for movies:
2.35:1
1.85:1
Movies like Star Wars, Lord of the Rings, and other "EPIC" movies are in the super stretch mode (it will fill only the middle portion of a normal 4:3 tv). (2.35:1)
The 1.85 mode is mostly for comedies and some drama bits.... The bars will only consume a small portion of a 4:3 tv.
Kevin
(I know there are other ratios but the VAST MAJORITY of hollywood movies use one of those two ratios
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
master yoda, is darth vader my father? i must know
Aspect Ratio Problem
By prismpecs in forum ffmpegX general discussionReplies: 1Last Post: 25th Oct 2011, 13:36 -
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 07:58 -
Problem with Apect Ratio when using XviD4PSP
By Znooky in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 15:12 -
Aspect ratio problem
By nlaak in forum DVD RippingReplies: 6Last Post: 4th May 2009, 16:13 -
By kewowski in forum MacReplies: 0Last Post: 2nd Feb 2008, 08:38
