Here's my issue i've been backing up various dvds that my friends made images of.. But the ONLY ones that will play in my standalone DVD player are ones that have an ifo file for each vob file. Most dvd's only have the main video_ts and the ts_1 or w/e. SO how can i create an ifo for each vob?
I've tried ifoedit to no avail.
ANY help ould be awesome i've gone through wayy to many blanks trying to figure this out on my own!
Thanks!
Results 1 to 15 of 15
public domain movies I hope
If you want just the main movie, move just the main movie VOBs into a directory on their own, then follow this:
http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit .
If you want something different, please list all of the files you have.If in doubt, Google it. -
VIDEO_TS
VTS_01_0
VTS_01_1
VTS_01_2
VTS_01_3
VTS_01_4
VTS_01_5
it came with an ifo for video_ts, and it made on for 01_0
but the rest won't work -
doesn't that just create on ifo for all the files though?
Would it just be easier to re-author the dvd? -
Hey, if you don't want or rate my advice, you don't have to follow it.
The way I have shown you will take the main movie and create IFOs for it so that when you insert the DVD, the main movie plays on insert. If you want anything else, I suggest you BUY THE DVDS YOURSELFIf in doubt, Google it. -
Don't get me wrong i very much appreciate your efforts
and i'm dumbdounded personally
NO one else seems to have this problem... so i have no idea what to do
For 1-5 it made two ifo's
video_ts
and
vts_01_0
i'm so confused
because my dvd player seems to need ifo's for each individual vob file... but that doesn't make sense because no one else seems to need them... ?
When i try to play them it says no disk..
which i don't understand
All i know is that ifo's tell the player language setting/ aspect, and chapter placement.. so why would it need one for EACH vob file? -
I think your problem is the way you're burning them. All files must be inside a VIDEO_TS folder on the disc. http://members.dodo.net.au/~jimmalenko/NeroExpress.htm might be able to help you with that
.... o....m...g
I think i know what the problem might be...
tyhe movies are PAL
they aren't named as "pal" but the ifo's say they are... maybe it was just a coincidence that those movies didn't have ifo's for each vob...
good god i just might be retarded
THANKS for the help tho dude, VERY much appreciated! -
Originally Posted by liquidfirex
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 13:07 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
