Does anyone know of any VirtualDub filters that allow me to blur an area of my video, preferibly in a oval or circle shape?
I'm trying to remove a logo from my video and the logo removal procedures I've tried all leave a fairly easily visible square block where the logo was.
create a image the size you need and use the logo filter
Region remove filter, by Shaun Faulds works for me.
Put a tick in the Soft Edges Enabled, and adjust pixels accordingly.
I use this filter on everything with a logo/watermark, and although it seems noticable in vdub, once encoded/authored/burned, most people never even notice it on the TV.Cheers, Jim
My DVDLab Guides -
I found this filter called LogoAway, and it works better than anything else I've tried. The quality is very good and it's not very noticeable with the right settings.
The only down side is that it can crash if you're testing the settings and you don't have just the right value. Other than that, it's great!
LogoAway
https://www.videohelp.com/tools?tool=Virtualdub_Logoaway_filter
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 11:27 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 09:48 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 14:07 -
Bluring/blocking out private parts
By Cruton502 in forum Authoring (DVD)Replies: 12Last Post: 17th Jun 2008, 09:56 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 18:48
