hello friends,
i've been reading problems about vhs to dvd capturing. some suggest that you use pass thru using sony dv cam... what is this? how do you do it ? well, correct me if i'm wrong..a pass thru is like this
from the vcr hi fi, connect the rga cacble to the video cam and from the video cam use the firewire cable, connect it to your capture card and when you press play on your vcr,video contents will appear on the video cam... am i correct? you see, whnever i want to transfer my vhs tapes to dvd, i use the same system as i have mentioned but I FIRST TRANSFER MY VHS TAPE TO HI8 TAPE AND FROM THERE I USE THE REGULAR CAPTURING SYSTEM BUT I NEVER USE NEITHER HAVE I TRIED THE PASS THRU SYSTEM!!!
PLEASE SOMEBODY COMMENT ON THIS ISSUE!!!
THANKS!!
If by this:
You mean your transferring you video from VHS to hi-8/D8 tape on a Digital cam there's no difference quality wise. By just transferring direct to computer your saving wear and tear on your cam, time too since you don't have to transfer twice if that is how you need to do it etc.Originally Posted by framig -
YES, YES AND YES, YOUE ARE VERY RIGHT!! THAT'S WHY I INQUIRED ABOUT THE PASS THRU SYSTEM HOPING THAT I COULD SAVE TIME HERE IN MY PRESENT SYSTEM.
I SAW THE BIG DIFFERENCES!! IF I CAPURE DIRECTLY TO MY COMPUTER VIA THE ANALOGUE OR RGA CABLE, THE IMAGES ARE SOMEWHAT SPREAD OUT MEANING IT IS NOT THAT SHARP AS CAPTURED THRU HI8 OR THE SYSTEM FIREWIRE.
WELL IF YOU CAN HELP ME FURTHER ON THIS PROBLEM I WOULD GREATLY APPRECIATE IT! BUT THAT'S ALL I KNOW SO FAR AS FAR AS TRANSFERRING VHS TAPES TO DVD IS CONCERN! -
On my Sony DV camcorder, it's fairly simple. You have to enable DV out on the camcorder from your camcorder's menu. Make sure that no tape is in the DV camcorder. Use the RCA cables that came with your camcorder to connect your VCR to your computer.
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
AVIDemux 1-pass vs. 2-pass Configuration Question
By robindean in forum Video ConversionReplies: 2Last Post: 12th Mar 2010, 20:32 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 17:58
