hi all, sorry i'm new to this, can i watch a vcd on the playstation one console, the model no. is scph5502, i already have the adapter for the rear to connect it to the tv. thanks in advance.
I don't have the answer but why don't you just test it with one of the VCDs you've made for your DVD Player?
I only dream in black & white...
MSN: paschendale@gmail.com -
thanks dhruv but i've already tried, and it didn't work, apparently it was unable to read the vcd, but it works on the computer no worries, they were back up copies too.
thanks anyway. -
bumpa i dont suggest you watch your VCDs with PSX ...PSX was not designed to play streaming video for a long time soo the lazer might get damaged and your PSX might over heat and render it useless...one other solotion is to buy a External fan to coll down the PSX.....i love the origanl PSX..what a classic
There's a plugin that goes into the port at the back. You'll have to search Yahoo for it.
bumpa,
I've previously done a comparison on my son's PSX (Model SCPH-7502) with a Movie Card Adapter.
In short, i'ts not worth it. While the picture was slightly more grainy when compared to the DVD player, the big let-down was the sound. The DVD player was far superior even though both were played through the same home theatre system.
Regards,
Ronin2 -
to all of the above, thanks all for your reply's, i have since found out that the newer version of playstation one can play vcd's through the adapter, but i don't think i'll go ahead with it, unless there is another solution.
once again thanks ronin2,shabubu,pinoy2201,and dhruv.
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 16:57 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 02:43 -
Playstation 3 - do they upscale non-BD DVDs?
By snadge in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Feb 2008, 19:35 -
We need a definitiv Playstation 3 Guide
By demirdag in forum Video ConversionReplies: 1Last Post: 17th Oct 2007, 11:02 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 21:57
