Get yours now![]()
The Beast is the most powerful flashlight SureFire has ever produced for civilian sale. Utilizing a xenon-fill high-intensity discharge (HID) arc lamp, it puts out 2000 lumens of blinding white light — 120 times the light output of a typical two D-cell alkaline flashlight. HID lamps are extremely efficient — for an equivalent power input they provide more than twice the lumens of incandescent lamps. An additional benefit: they have no filament to break or burn out so they should never need replacing.
The Beast is constructed from aerospace-grade aluminum with an extremely rugged Military Specification Type III hard-anodized finish. It features a unique rotating switch — push counter-clockwise for momentary-on or twist clockwise for constant-on — and a lock-out tailcap to prevent accidental activation during transportation or storage.
Designed for open-area tactical applications such as border patrol, maritime interdiction, and long-range target identification, The Beast performs under all weather conditions. And it’s brutally tough — so resistant to mechanical shock and vibration that the U.S. military has adapted a version for use on heavy machine guns.
Power is supplied to the Beast by twenty 123 lithium batteries held securely inside four cylindrical chambers machined into the flashlight body. In combination with the highly efficient HID lamp, these energy-dense batteries provide a remarkable runtime of 1½ hours.
Only 85 Beasts are being offered for sale to private citizens. Limited to one per customer and available exclusively through SureFire, each one is serial numbered and comes in its own waterproof, airtight Hardigg Storm Case® along with a letter of authenticity from SureFire founder and CEO John Matthews.
* Batteries - Twenty SureFire lithium SF123 3.0 Volt with 10-year shelf life (included)
* Lamp assembly/Runtime – xenon-fill High Intensity Discharge (HID) arc lamp with 2000-lumen output for 90 minutes
* Construction – CNC-machined aerospace-grade aluminum; MilSpec Type III hard anodizing for corrosion and wear-resistance; Pyrex® window for improved scratch resistance; and built-in circuit breaker
* Length and weight (with batteries) – 14.75 inches/ 3.25 pounds
* Flawless white beam, always in focus
* Up to 120 times brighter than a typical two D-cell alkaline flashlight
* 3.85-inch reflector maximizes beam range
* Single hand operation with thumb-activated switch and lock-out tailcap
* Self-defense tool, bright enough to temporarily blind an opponent
* Waterproof, airtight Hardigg Storm Case®
* Rubberized bezel protector
http://www.surefire.com/maxexp/main/co_disp/displ/prrfnbr/24204/sesent/00
Results 1 to 19 of 19
Hello,
WTF??????
No USB port??? Why buy it???
Seriously who in there right mind would buy that????
Terrorists wanting to blind pilots on approach to airports!!Originally Posted by yoda313
Hello,Originally Posted by Ripper2860
No I think asked "RIGHT MIND"!!!
No politics so I won't go any further......
Are you inferring that left-handed people are terrorists !!???Originally Posted by yoda313
:P :P :P
"Right Mind" == left side of body
I know. It made sense when I posted and there really is a tie in, but you know what -- if you gotta expalin it -- it's not funny.Originally Posted by BJ_M
you always got to explain it in OT :P
"And it’s brutally tough — so resistant to mechanical shock and vibration that the U.S. military has adapted a version for use on heavy machine guns."
I've been looking for one to mount on my .50 Barrett:
http://www.geocities.com/landofsnipers/weapons/barrett82ENG.htm
"Batteries - Twenty SureFire lithium SF123 3.0 Volt with 10-year shelf life (included)"
20 freakin batteries?! That's like $50USD! -
$15 US for the batteries -- they are on the same page
for $2900 you could do a lot betterOriginally Posted by Calypso"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Yep, you should fit right in here....
Border guard so when he whacks Jose over the head it's lights out....For Jose not the flashlight. Guess the same applies for any enforcment or military position.Originally Posted by yoda313
with less than 2 hours run time ... he should start wacking as sooon as possable ..
prediction: "Bulldozer" will be a beast
By deadrats in forum ComputerReplies: 6Last Post: 3rd Oct 2011, 07:37 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 02:03
