Is such a thing as a video capture card and a video card that is one card?
One that has TV tuner input and monitor output?
I haven't been able to find one
Hello,
It's called an ATI all-in-wonder card.
Just do a search at bestbuy.com or circuitcity.com for all-in-wonder.
They have the graphics and capture function all in one. And they can record in avi or mpg mode
you must not have searched very hard because they are common. just google for video capture cards w\tvout.
hmm well i'm looking in newegg under ATI and they don't have any that have a COAX connector for the TV input and a monitor output
*EDIT*
They don't have one that has a standard monitor connector and the RF connector. All they seem to have are RF in and HDTV outputs -
Hello,Originally Posted by 808smokey
Try ebay for older models. You won't get as much graphics power but the capture function will be the same
Does it have to be all on the video card? You can get an entry level tuner card from ATi for $60 and use whatever video card you've got already. What are you using this for?
FB-DIMM are the real cause of global warming -
This guy at my work is on a bidget and doesn't have any PCI slots left. I think the Mobo only had two slots and they're both used (NIC & sound card).
I use a winfast 2000 & a TI4400 card for my setup. I've never used the ATI AIW. I'm gonna tell him to look on ebay. Nothing is that cheap now a days. The cheapest thing on ebay was a 9200se for $75.00 NIB.
Anyhow thanks for the help
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
select a video capture card that compatible with FMLE & linux
By iut_662 in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2009, 03:05 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 15:50 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
