Can someone point me to a tutorial about DVD structure? I've looked on Yahoo and all that turn up are tutorials on ripping.
I just want to learn more about making menus and the process involved with making the structure (ie. taking episodes from several TV shows and making a menu to choose which episode)
Thanks for your help guys
The easy way (or at least the way i have done it)Originally Posted by AlucardXXVII
Use DVD Shrink to strip out the episodes that you want.
Use an authoring program to create DVD with menu.
<------ See on the left here under tools / guides to help you
others can suggest the best authoring prog to use......i rarely use one so have no preference -
Hello,
This is a good place to start for info on authoring a dvd:
https://www.videohelp.com/author
If you want to know the INTERNAL structure of a DVD this has more than you'll ever want to know:
http://www.dvddemystified.com/dvdfaq.html (worth browsing through when you have some time
Basically you can make a menu as complex or simple as you want. If you backup with dvdshrink you can keep EVERYTHING or reauthor for just the episodes as zworg2 suggested.
Programs like Tmpgenc Dvd Author can accept vobs directly so if you have space left over you can make your own menus from the ripped episodes.
It's really all up to you.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
DVD Shrink structure problem
By janefield in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2010, 08:11 -
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 22:41 -
Change DVD link structure (i think)
By nOmArch in forum Authoring (DVD)Replies: 0Last Post: 4th Apr 2009, 10:09 -
invaled DVD navigation structure.
By Itsmeshane in forum DVD RippingReplies: 2Last Post: 10th Feb 2009, 18:23 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2009, 23:58
