I have been trying to select pal to ntsc conversion on the setup screen and yes I do click the checkbox. But if I try to save the settings on the page and then come back to the settings page the checkbox is unchecked again. How do I get the box to stay checked so that I can use the conversion tool? Is the setting on if I leave the screen without it being saved?
Any help would be great.
thanks
- Knewknow
Oops... well I just did a bit of testing and I guess the option to convert from pal to ntsc just cannot be set to default. Sorry for the lame post.
Thx
- knewknow -
Well spotted. I will fix that.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
PAL to NTSC - when do i select this option whilst editing & dvd authori
By johnnybravo in forum EditingReplies: 6Last Post: 24th Jul 2008, 11:23 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
