hello every one
i recently bought a BenQ 8X DVD+R 25 pack. i burned a few back ups but the thing is is that the BenQ 8X DVD+R doesnt play on my standalone DVD player (check my profile to find out my standalone). however, the DVDs which i backed up from (Memorex 4X DVD+R), they do work. so what could the problem be here?
Results 1 to 11 of 11
Wow! You got shocks, pegs... LUCKY!
try some quality dvd's. stop buying junk like benq. go to rima.com and get some taiyo yudens. you won't be disappointed. or stick with your memorex.
BenQ 8x DVD+R carries a Daxon media code, and they're supposed to be decent but not the best. It's possible the Memorex discs were RICOHJPNR01 which are (were?) very high quality and that may explain the difference in performance.
so what brands would you recommend?
Wow! You got shocks, pegs... LUCKY! -
o BTW thanks for the posts
I've got a BenQ burner and their 4x discs work fine in all the players i've played them in. Are you bitsetting to -ROM?
um i dont think i am, actually to tell you the truth i wouldnt even know what or how to biset...
however i did read somewhere that -R play on most DVD players, and the +R are a minority ( i think it was WIKIPEDIA). so even if i did accidentally BITSET to -R, whouldnt there not be any problem?
o BTW, i did try the same DVD+R in a CineVision DVR 1000 DVD+VCR Dual Deck, and it worked fine. if it makes any difference, happy posting...
sorry i meant +R and -R.
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ulead DVD Movie Factory won't burn DVDs after had been working fine
By alh132 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2009, 16:47 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Splitting Episode DVDs in 2 with working menus
By 1980sumthin in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2007, 22:29 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
