Hello, I have a Panasonic DVD Recorder (standalone TV one) and it uses DVD-RAM discs, I've been recording things onto them but I'm - obviously - unable to play the discs on any standard DVD player. So, I've been looking into DVD-Writers for my computer but if I got a DVD-Writer that could read DVD-RAM discs, would it be able to copy them seeing as the Panasonic Recorder doesn't have a "Finalize" or "Make Compatible" feature?? I don't want to spend the money only to find it doesn't work!
Thanks in advance
ANY recent Panasonic DVD player will play DVD-RAM. If you buy TMPGEnc DVD Author, you can easily make DVDs with the RAM disc on your computer RAM drive.
I have a Panasonic dvd writer lf-d521, its reads that & writes to dvd-r too...
Originally Posted by egspeedle
http://www.avforums.com/forums/showthread.php?t=101191
Your DVD-RAM discs are recorded in UDF Ver 2.01, and you need to make sure your computer is installed with a UDF reader or using either WinXP Pro or Win2003, otherwise your computer cannot read the content of the disc.
Why don't drives read HD-DVD anymore?
By Sephiroth666 in forum Blu-ray RippingReplies: 40Last Post: 10th Dec 2009, 17:48 -
Trouble with DVD Drives
By Cody_L in forum ComputerReplies: 3Last Post: 25th Dec 2008, 14:06 -
connecting laptop to PC and using both DVD drives
By debrag in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Oct 2007, 11:20 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
