i want a dvd to play the non defualt audio first. how to i change the defualt audio selection to one of the secondary choices.
any help or guides?
thanks
J
Open the IFO for the movie and then up top select VTS_PCITI. If there is more than 1 PGC then click the arrow to expand it and select the PGC you want to modify.
You will see a little bit below lines saying audio stream 1 status, audio stream 2 status, etc...
Next to the first one it will have the number: 32768
The second will be 33024.
Lets say you want to reverse playback of these two, so that the second audio track now plays by default. Just click on the numbers for each of these and reverse them. Make track two say 32768, and that will make it the default track.
Make sure and save the IFO when you're done.
Set default audio device in VLC from 5.1 to Stereo?
By Xenogear900 in forum Software PlayingReplies: 3Last Post: 28th May 2011, 04:43 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 01:12 -
TMPGEnc AW 4: default audio stream for different tracks
By reini in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2009, 15:33 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 20:10
