when trying to cut divx avi's i assume you need to get the bit rate correct. or can i just assign any reasonable bit rate and vdub will reencode the already encoded divx ??
how does vdubs cutting work ?
i cant seem to cut regualar DV avi's also, they end up as uncompressed AVI 5 ,6 times bigger than the original source. is there a decent vdub cutting tutorial ??
I think I'm close. I opened the AVI, went to Video, select range, selected about half way through, then chose Save as AVI but it wanted 3.5GB for a 290MB file...
Ideally I need to split the MPEG if possible.
Help?
Possible To Make A VDub Script To Cut Segment From Video?
By onesikgypo in forum ProgrammingReplies: 1Last Post: 17th Jun 2011, 20:02 -
Editing .wmv in Vdub
By imdaman in forum EditingReplies: 9Last Post: 9th Jan 2010, 16:09 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 17:21 -
editing movies in vdub: how to get whole vid in memory?
By SignedupGuest in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2008, 08:14 -
Vob / Mpeg2 editing with Vdub
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2008, 17:55
