If I'm just capturing using a Canopus ADVC-100 box, do either of these/any of these decoder/encoders help me?
I'm using Vegas Movie Studio to create my "movies" and then frameserving them to TMPGEnc.
nope - dv is a transfer .. doesnt mater what type of codec you have for this operation as the compression is done in the device -- and vegas uses its own codec for RE-encoding DV
Vegas Movie Studio includes the MainConcept MPeg1 and MPeg2 encoders. So you are set.
Edit in DV format.
If you want to make a DVD, you have MainConcept under the hood already. -
he was asking about the main concept DV codec , not the mpeg encoder - but you are right about the mpeg encoding ..Originally Posted by edDV"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Actually, in this instance they do make a difference, because the canopus box is using the canopus codec (in hardware) to create a DV stream from an analogue source. If you were to do an editing in Vegas an output to an avi file (as a DV stream), then the Sony DVV codec would be used to create any new footage (cross fades, credit overlays etc). As you are frameserving, this may not be an issue.
Read my blog here.
Originally Posted by guns1inger
thats what i said -- but since he is using sony studio , other dv codecs on his system dont mater ...
so the answer is still "NO" --- doesnt mater on the ones he asked about ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I use Canopus ADVC-100 and Sony camcorder DV input to Vegas every day, edit in Vegas 5 (or Premiere) and output DV to the camcorders or to MainConcept MPeg2 (or MPeg1) and everything just works fine.
Canopus, Sony and MainConcept play well together.
>>add ULead's DV and MainConcept codecs to that. They all work together.
Is there some issue of compatibility between the Canopus and Sony DV codecs? I though Canopus licensed the Sony DV codec algorithm in the early days and Canopus pledges compatibility.
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
