Im trying to split a divx movie using virtual dub, into two halfs, so i can make a vcd out of it
They way that i've been told to do this, is to select the first half of the movie, and delete the rest
then save it out as a avi again
OK no probs for the first half of the movie
but when i do the exact same thing to the second half
(selecting the first half and deleting)
the video saves properly, but the audio is WAY off
its not cutting the audio at the correct place or something
any ideas?
Results 1 to 1 of 1
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 21:57 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
