Well right before I went to burn my dvd i put together i ran into a little bump in the road... I am using DVDAuthorgui for the first time and im using an srt type for the subs.
here is what it looks like via screenshot
and here is what it looks like when i load the file into DVDAuthergui
and here is the subtitle line
16
00:00:47,480 --> 00:00:48,370
16,,Style1,,0000,0000,0000,,Commencing operation.
should I just remove all the 16,,Style1,,0000,0000,0000,, part or convert to a different subtitle format... and which format? Thank you all for the help
Results 1 to 10 of 10
Seedin and encoding... Healthy pc life :)
just remove 16,,Style1,,0000,0000,0000,,.i`ve edited srt files before and it works.
ahh crap... *sighs* i wonder how long its going to take me...
Seedin and encoding... Healthy pc life :) -
That looks like a .ssa line, not a .srt!?!
Maybe a bad ssa to srt conversion?
/Mats -
Should only take a minute to remove that line and save the file,its just basically a text file with a srt extension.
its more than just that line... its all the lines... and i used virtualdubmod to extract the subs and it came out in srt format
Sounds like the original ripper goofed up on the sub to srt,you gotta redo all the text or look for replacement srt.You might be able to find a text editor that will remove that specific line if its the same for all the lines.I just tried a document on ms word and it will remove all common sentences you specify.
Take my word - it's not a .srt file you've got - it's a .ssa file!
Either way, it's a plain text file, and editable by hand in any text editor, or using some dedicated subtitles editor like subtitle studio.
Could you open it in Notepad and post the first 10-20 lines?
/Mats -
ok i fixed it all and loaded it all into dvdlab pro... dvdlab reconised it all and well... made the videots folder and when i went in to check it out with windvd before i burned it... NO SUBS. i right clicked and nothing will display... used other programs and still... NOTHING.
Was i supposed to click on the generate subtitle stream in the subtitles section... or was selecting the "select this subtitle on by default" plus adding in the VM command of SetSTN(subp=0
n) to each episode my down fall?
sorry man i already edited the subs after you posted... here is what the first 5 lines look like nowOriginally Posted by mats.hogberg
1
00:00:39,470 --> 00:00:40,640
Amazing!
2
00:00:40,640 --> 00:00:44,970
Her maximum range is up by 10%,
and her accuracy is at 98%.
3
00:00:46,010 --> 00:00:47,340
She's almost perfect.
4
00:00:48,680 --> 00:00:50,510
She'll finally be
of some use now.
5
00:00:51,750 --> 00:00:53,040
Send her home
for today.Seedin and encoding... Healthy pc life :)
subtitle problem
By cloudsong in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2011, 17:18 -
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 10:44 -
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 04:32 -
Subtitle Problem
By simonrule in forum SubtitleReplies: 1Last Post: 10th Oct 2009, 18:59 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
