Hi,
I have some VCDs that I can no longer find in stores. I would like to back them up. But I found out that the VCD is corrupted. It still plays, but I have to load it into the tray a couple of times before the system recognizes it.
When I tried making an image of it into my PC, and gives me an error message and shuts down the operation.
How do I save a copy of this movie? It does have to be a VCD again. I just want the movie playable.
Results 1 to 9 of 9
Thanks, but it did not work.
It was stuck at 3% for half an hour. It cannot be saved.
Find a white wax candle. Rub gently all over the media surface (not the top silly
), polish with a soft, lint free, cloth.
Try again.
I've ressurrected many (S)VCD/DVD that my kids have had "hands on" experience with.Cheers, Jim
My DVDLab Guides -
I have had it stay at 6% for 2 hours and got everything off the CD.Originally Posted by Cyberian v2.0
Which is the surface and which is the top? Surface and top is the same to me.Rub gently all over the media surface (not the top silly ),
Upon the first bad sector, a pop up screen showed up. Which did you choose out of the 4 options?I have had it stay at 6% for 2 hours and got everything off the CD. -
Heh, media surface would be the bottom. Sorry for the confusion.
Cheers, Jim
My DVDLab Guides -
http://www.smart-projects.net/isobuster/help/
I'm not sure if you can do what you want with the free version.
Corrupted MP4 in QT
By Klagar in forum Video ConversionReplies: 4Last Post: 27th May 2011, 08:28 -
corrupted mp3
By knutrockney77 in forum AudioReplies: 1Last Post: 22nd Apr 2011, 04:21 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
corrupted dv file
By marshs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Aug 2008, 18:40 -
Registry corrupted
By zoobie in forum ComputerReplies: 9Last Post: 11th Jun 2007, 12:57
