A friend of mine gave me the Star Wars Trilogy on DVD for Christmas.
But since he's French, the DVD are region 2 PAL.
I can watch all DVD on my computer here in the US but my living room DVD player won't play them (it's a Toshiba SD-K600). The TV displays an error message regarding the region since my DVD player will only accept region 1.
I ripped one of the DVD with DVD Decrpypter and burn a copy with DVD Shrink. I thought that DVD Shrink had the ability to make the disc region free but once I played the copy, the error message regarding the region is gone but this time I have an error message telling me that the disc is not NTSC.
What should I do? Is there an easy way to make a region 2 PAL DVD play on a region 1 NTSC player?
Thank you so much for any help!
Hacking a player usually just reprograms it to ignore region coding and/ or remove copy protections. It's the actual hardware that takes care of any needed TV system conversion. If your Toshiba can't play a PAL disc even though it's region free, it probably means that the player just wasn't built to do it in the first place.
If this is the case, you can convert the DVDs to NTSC, but you're better off getting an NTSC version and backing up that. After all, you do own the trilogy discs now.
How to watch PAL VHS on NTSC tv
By wolfhunter in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 15:36 -
using NTSC TV as external monitor to watch PAL dvds played on laptop
By billybadbreaks in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2009, 15:27 -
Capture/DVR Projects -- TV Movies: Star Wars Trilogy(s)
By vhelp in forum Off topicReplies: 14Last Post: 11th May 2008, 21:35 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Diff languages in Star Wars conversion.
By neomaine in forum DVD RippingReplies: 0Last Post: 5th Feb 2008, 09:06
