Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 23 of 23
  1. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Hello,
    TDK has introduced three types of inkjet printable media. Of interest, is the "photo quality".
    Here is the linK: http://www.tdk.com/recmedia/dvd/printondvd.html
    Originally Posted by TDK website
    PrintOn DVD Photo Quality is the ideal solution when a glossy photo print look is desired.
    ...Specifically designed for epson inkjet printers..
    Humm, sounds good to me
    Anyone has tried them?
    May 2004
    Apparantly Costco carries them in the USA, I don't know of any other places.
  3. Member Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    What are the prices at Costco?
  4. tgpo famous MAC commercial, You be the judge?
    Originally Posted by jagabo
    May 2004
    There's a thread in this forum on them.
  6. Member maldb's Avatar
    Dec 2002
    $30 for a pack of 50 = 60 cents each
  7. I think their 39.99 for a 50 pack matte,anyone know the media code their made in tiwan.
  8. Costco:
    Apparantly
    $30
    $40
    Has anyone actually bought them there?
  9. Member maldb's Avatar
    Dec 2002
    Originally Posted by stiltman
    Costco:
    Apparantly
    $30
    $40
    I made an earlier post about this. The Costco in Staten Island, NY has them (50 per pack) for $30+tax.
    I didn't buy them because:
    1 - don't know the media ID
    2 - saw that they were made inTaiwan (CMC?) [yes I held the pack in my hands and read the label]
    3 - at 67 cents each, I can buy Taiyo Yudens (I'd rather be safe)
    May 2004
    I think all TDK 8x DVD-R media in the US is TTG02. Haven't heard of any other media codes being supplied.
  11. The spinal wrapper says 8X but my BTC/Emprex 1016im only sees it at 4X
    Print area is 116mm x 39mm or 4 9/16 x 1 9/16
    Here's the rest of the info
    00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 85 0D 0C .l...@....R.....
    00000010 87 89 90 00 03 54 54 47 30 32 00 00 04 00 00 00 .....TTG02......
    00000020 00 00 00 00 05 BA A3 22 32 20 02 00 06 09 0A 15 ......."2 ......
    Media Information
    Region information-----------------------N/A not a DVD-VIDEO
    Media code/Manufacturer ID------------TTG02
    Format Capacity--------------------------Not Formatted
    Free Blocks--------------------------------411107328
    Free Capacity------------------------------4.38GB(4.71GB)
    Book Type----------------------------------DVD-R
    Media Type---------------------------------DVD-R
    Media Id Code Speed---------------------Unknown
    Available Write Descriptor----------------CLV 4.0x 5540KBps
    Write Strategy Speed---------------------4.0x 5540KBps
    2x Speed OPC beta-----------------------09
    2x Speed OPC power----------------------0A
    2x Write Strategy field 1-----------------15 98 89 90
    2x Write Strategy field 2-----------------88 80 00 00 00 00
    4x Speed OPC beta-----------------------05
    4x Speed OPC power---------------------15
    4x Write Strategy field 1------------------0C 0E 09 04
    4x Write Strategy field 2------------------96 05 0B 0B
    4x Write Strategy field 3------------------80 00 00 00
    4x Speed OPC beta multi-pulse----------09
    4x Speed OPC power multi-pulse--------18
    4x Write Strategy field 4------------------14 97 88 85
    4x Write Strategy field 5------------------B8 9A B8 83 00 30
    4x Write Strategy field 6------------------00 00 D0 00 00
    Data area starting sector-----------------30000h
    Linear Density-----------------------------0.267um/bit
    Track Density------------------------------0.74um/track
    Number of Layers--------------------------1
  12. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Stiltman,
    Did you really buy real "PrintOn" dvds?
    Please let us know how they look when printed. These are the first to claim "glossy photo surface".
  13. Originally Posted by RickTheRed
    Stiltman,
    Yep, just picked them up an hour ago.
    They are not glossy finish though. They are white matte finish
    I'll add it to the media section if it hasn't been done yet
    EDIT:
    Think I'm going to return them as they don't burn at 8X and the printer area is not all that big. I'm used to hub printable 118x22
    EDIT2:
    Plus I think the print out isn't as good as Prodisc S03/4 even after a seal coat sprayed on
  14. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    Stilman I had this problem with 4x's TDK on a Lite On 451s they only showed up as 2x's.
    But other drives burned them at the correct 4x's.
    This could be a safety feayre built into TDK's. Maybe they think somedrive are inferior so they force lower burn speeds.
    It happened to me on the Lite On 451s with TDK dash/minus but not the plus. And of course Lite On likes plus better.
  15. I bought the PrintOn discs also and eventhough it says 8x, they only burn at 4x on my NEC 3500 and my NEC 6500
  16. Na it's just the firmware of this drive
  17. Originally Posted by aanaravs
    You need to update your firmware on the NEC. Look at the TDK bestbuy thread
    BTW, Burned just fine on my 106D and my BTC1016IM, albeit at 4X
    They're still going back tomorrow though
  18. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Stiltman,
    As per the link above, PrintOn DVDs comes in three formats:
    1- Photo quality DVD
    2- White matte
    3- Color matte (same as white but already colored)
    Only the first one is supposed to be "glossy"
  19. Originally Posted by RickTheRed
    Stiltman,
    2- White matte
    Yep, and I posted what I bought
    Also if you look at the link, the photo glossy are only sold singles and the 8x media I bought says 4x least on their site
  20. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    i got a stack of the +r sitting infront of me. my boss bought them not knowing that his standalone only uses dvd-r so he gave them to me. i guess he got them from costco. ill post the media code when i get home in a little while
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  21. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    00000000 08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
    00000010 00 00 00 00 00 00 03 43 4D 43 20 4D 41 47 00 45 .......CMC MAG.E
    00000020 30 31 00 38 23 54 37 10 02 38 6A 02 88 67 15 15 01.8#T7..8j..g..
    00000030 0B 0B 08 08 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID CMC MAG E01
    Media Product Revision Number 00h
    Format Capacity Blank Disc
    Free Blocks 405405696
    Free Capacity 4.38GB(4.70GB)
    Book Type DVD+R
    Media Type DVD+R
    Manufacturer Rated Speed 8.0x 11080KBps
    Available Write Descriptor CLV 8.0x 11080KBps
    Available Write Descriptor CLV 6.0x 8310KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    umm yeah, stay away from the +r's. glad i didnt pay for them so how many prodiscs are worth 50 cmc's? i feel kinda bad just taking them
  22. Guess I will stay away from the +R, but why are you guys complaining about it being 4x, you guys can't wait an extra 4 min. What's the big deal, for a TTG02 quality dvd and printon disks for that price, I don't think there is a better deal out there, I go to blankmedia.ca and buy 50 TY 8x for $49.00 + shipping, and this is the best price I can find. I think the TDK's are the ones for me, then again that's my opninon..
    Good thread though....
