I have a question concerning the titleset menu in Dvdauthorgui (latest version .997 I believe). I ran into the problem where the program immediately closes when I try to open the titleset menu. Read the forums and found that I needed the support files. Downloaded those and the program will now advace to the titleset menu but I am now getting a blank screen instead of showing my .jpeg that I converted and saved as a .m2v still.
Has anyone else ran into this problem? Am I missing another codec? Like I said above, I downloaded and installed the support files.
Thanks in advance for the help, I'm a newbie. I appreciate it.
I do have the full Powerdvd already on my computer. I included a couple of screenshots (.jpegs) to show you there may be a problem trying to install the batch files in your support files download. It acts like it is not finding a couple of the specified files.
I dont know what else could be wrong. Is there a way to check the registry to see if the gplmpgdec is actually registered? Could you send me the gplmpgdec.dll file and I could manually put it in?
Again, I appreciate the help.
dvdauthorgui menu question/problem
By tacitus in forum Authoring (DVD)Replies: 7Last Post: 11th Oct 2011, 21:53 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 07:04 -
DVDAuthorGUI: Menu problem
By videohalp in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2008, 21:11 -
Authoring a VOB Titleset to create a Menu w/o Re-Encoding?
By Moontrash in forum Authoring (DVD)Replies: 3Last Post: 15th Jun 2007, 11:54
