Hi there,
I have been trying to capture the audio from an AVI file using VirtualDub 1.6.0. Although I can play back the video in Real/WM player it gives me a compressor error when I use VirtualDub. The error I get is:
'No audio decompressor could be found to decompress the source audio format'
Any help? Cheers
Bizt
Results 1 to 12 of 12
Try virtualdubmod.
Check the file in gspot too.Cheers, Jim
My DVDLab Guides -
Hi,
I have downloaded VirtualDub Mod but dont know how to capture only the audio, which I will then use in TMPGenc Xpress.
I had a look for guides on doing this but didnt see any on this only. Can somebody please instruct me how to do this or give me the url. Thanks
Bizt -
Open the avi in vdubmod.
Click Streams, stream list.
Select the audio.
Click Save WAV.Cheers, Jim
My DVDLab Guides -
Thanks Jim, I knew that! (brain fart, and forgot to mention it tho).
Cheers, Jim
My DVDLab Guides -
Hi,
Ive used VirtualDub Mod and it works when I dont choose 'full processing mode'. Its only when I choose 'full processing mode' that it gives me the same error as I had in the beginning.
Unfortunately the resulting file, when saved without full processing mode, wont work in TMPGenc Xpress. What is 'full processing mode' anyway? Also, is there any reason why it work work when this is used? Cheers
Bizt -
Full Processing Mode means that VirtualDub will try and decode the audio (for which it has to use the decoding part of the codec). If instead you use Direct Stream Copy VirtualDub will not try and do anything to the audio stream.
I would recommend using GoldWave to decode the audio from avi's if they are giving you problems - just open up the avi in GoldWave and then save as a wav. It seems to work on pretty much everything (including AC3 etc..)
Alternatively (and this is not much different) use VirtualDub in Direct Stream Copy mode to separate the audio stream (save it as a wav, although it will not really be a PCM wav file) and then open that wav in an audio editor (e.g. GoldWave, Audacity, SoundForge, CoolEdit etc...)
What does gSpot actually say about the codecs in use in your file? The approach to use to decode it to wav manually really depends on what sort of codec is used.
cheers,
theDruid.
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 12:16 -
A virtualdub problem
By General Mortars in forum ComputerReplies: 4Last Post: 10th Oct 2010, 06:01 -
VirtualDub Problem
By jarko in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 12:26 -
problem w/virtualdub
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 23:09 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
:P
