  1. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Hello all. I'm new to DVD burning and am wondering if any Canadians, from Ontario, have used the blank, PC4Canada branded DVD-R media that is available at the PC4Canada store. They're extremely cheap, but has anyone used them? Do they actually work?
    Thanks,
    MJ
    Aug 2004
    Toronto, Ontario, Canada
    I bought some similar media from another Toronto store that turned out to be very bad (Yi Jhan 001). They worked, but only if I didn't burn them past 4GB, and only about 75% of the time then. I have learned my lesson and I now buy better. For example, the Benq they sell at Future Shop on sale works really well for me, and right now a 200 pack is $60 (I bought 25 for $10). I won't touch anything that cheap again unless I can test a 10 pack at the most.
  3. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Hi BetaMaster. THanks for replying! What kind of burner do you have?
    Cheers,
    MJ
    Nov 2003
    Ontario, Canada
    Cheers,
    MJ
    His profile says "Lite-On 812S".
    Yi Jhan 001 = crap
    www.nomorecoasters.com
