does it work good is it really cheap ?
Is it cheap? Look at the prices and decide for yourself.
Does it work? Yes. My friend uses SkypeOut to call Norway from the UK all the time. -
Yes, I use it for calling a few countries. Works great in case of emergencies and such.
How's the sound quality? My dl is 3megs and up is 500kb. Does the quality change depending to which country you call?
For me the call quality has been pretty constant actually. Sometimes, the calls do not work though, because of some server problem, but most of the time they calls get through easily.
Recording voice calls how to eliminate echo
By planetx in forum AudioReplies: 12Last Post: 25th Mar 2011, 07:41 -
Video calls on mobile phone capturing.
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 8th Mar 2009, 17:48 -
Tracking calls on a PC
By chewie8008 in forum ComputerReplies: 1Last Post: 13th Jan 2009, 23:39 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
Prank calls on Telemarketer
By waheed in forum Off topicReplies: 0Last Post: 13th Jun 2007, 04:54
