[Please note: I posted this to the ffmpeg forum first; I'm re-posting it here in case anyone more knowledgeable about Toast 6.0.7 than I am knows anything about Toast's converting of the original audio to - apparently - .sd2 audio format. Or if you know anything about how Toast sizes up the destination output size depending on whether you have "DVD" or "(DVD+R) DL" chosen. - Ed.]
Say I've got 2 AVI (XviD) files. They're both encoded using the A52 AC3 audio 5.1 codec.
I get the AC3 QuickTime component and install it. I use QuickTime Pro and concatenate the 2 AVIs together and export to a self-contained QuickTime .mov file.
I want convert this .mov (back) to a burnable DVD (UDF). I try the simpleton's method (Toast) first; it looks to me like it's re-encoding the audio as ".sd2" (Sound Designer II format?!?), 44.1 kHz. Looks to me like Toast is going to strip the 5.1 mix and produce a stereo mix instead. Bad dog.
So, I thought I'd try ffmpegX. Anyone with suggestions on settings to use? I'm assuming for "Audio" I'll select "Passthrough" and un-check "Encode audio", right? (If I do this, I assume all the "Audio parameters" settings are ignored, correct?)
Now the fun part - the video. I assume I should choose "MPEG2 [.MPG] (ffmpeg)" (or "(mpeg2enc)", whatever) and check "Encode video".
The rest of the settings - "Video", "Options", "Tools" - I have no clue about. When you go from AVI (back) to DVD, you can't put in what isn't there anymore, right? So I don't know whether to select DVD/4000 MB under "Bitrate calculator", or whether to change the 4000 MB to 8000 MB (I have a Pioneer DVD-108 DL-capable burner). I don't know whether to change the PAL rate of 25 in "Video parameters" -> "framerate" to NTSC or not ("Info" says the .mov is 25 fps; I have an American - i.e. NTSC - DVD and TV setup, not sure it can play PAL). I don't know whether to use "2.35:1" or "DVD 16:9" in "Video parameters" -> "Autosize".
All I want to do is to get this .mov onto a DVD-R (or DVD+R DL) disc so I can view it on my TV, hopefully with the AC3/A52 5.1 mix intact. Can anyone make settings suggestions based on this?
Closed Thread
Do not crosspost.
video player that can step forward/backwards and change play speed
By wildflow in forum Software PlayingReplies: 5Last Post: 5th Jul 2012, 18:16 -
Backwards running
By Zenner in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 09:41 -
WD player (can it play backwards ?) recertified ?
By Umen Pich in forum Media Center PC / MediaCentersReplies: 1Last Post: 3rd Jun 2010, 06:59 -
Gui for dvdauthor ERR: SCR moves backwards from...
By lienny in forum Authoring (DVD)Replies: 35Last Post: 24th Feb 2009, 05:18 -
USB 2.0 hubs (backwards compatable)
By guitardan in forum ComputerReplies: 4Last Post: 25th May 2008, 10:01
