Newbie question Can someone point me in the general direction of a Numpty guide on VHS tape to DVD conversion and the best way to do it.
Is it best to link a Video Cassette recorder to a DVD recorder or link the Video Cassette to my PC (how??) and burn that way.
I just want to transfer my old F1 video tape collection to DVD, not bothered about retaining any digital file on my PC or anything al though that would be nice if it's easy enough to do.![]()
Hello,
Here's a good place to start:
https://www.videohelp.com/capture
A capture card on a pc is easy to use and install if you've ever installed a pci card before. (some usb units can be good but I've only used a pci card).
They will record to avi/mpeg depending on the card and then you author and burn it to dvd.
A settop recorder is much easier but less flexible.
Kevin
(do more reading too, it will help)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 01:16
