Thanks!
Results 31 to 42 of 42
Originally Posted by BJ_M
large
IIRC, "large" describing volume size was proposed my MS to be anything over 124 gig...whatever that number was that created the "bug" in XP with drives over that size. I think it was ~124 gig. There's an update somewhere on the MS site for it, and both SP1 and SP2 have it corrected anyhow.
Cheers, Jim
My DVDLab Guides -
127GB
OK... so my performance will be better with NTFS... will update tonite.
Only have 9 gig on there now... is it best to move to another drive, create new partition, format, and move back OR convert. Advantages of one vs the other?
Thanks -
Originally Posted by Dr. DOS
Originally Posted by tekkieman
You should be able to improve performance of NTFS drives by changing the cluster size. For example a 2 GB NTFS partition would by default have a cluster size of 4k. A FAT32 formatted drive has a 32k cluster size. With NTFS you can manually force different cluster sizes (done via command prompt, I don't remember the command and switches off hand). You can also use a tool like Partition Magic to change the allocated cluster size. In general, the larger the NTFS partition, the larger the cluster size. 4k, 8k, 16k, 32k, 64k (although 64k is not recommended).
**Warning, using the command line method will destroy all data on the partion**
The reason NTFS is slower on smaller drives is because the clusters are 4k, thus larger files require more reads/writes than a FAT32 partion with 32k clusters. However, 4k clusters are more efficient when it comes to space. The reason is every file, regardless of size, occupies at least one cluster. So if you have a file that is 800 bytes on a FAT32 partition, that file will occupy 32k of space (one cluster). Different files can not "share" a cluster. A NTFS drive with a 4k cluster size would only have 4k occupied by the same file.
As you can see, it is a trade of space for speed. I usually partition my NTFS drives with no smaller than 16k clusters.
[Begin Sarcasim]...and that concludes todays lesson. You will be quizzed tomarrow, and don't forget your homework![/End Sarcasim]Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Suprised when I converted last nite I could not rightclick on drive in Drive Management and select 'convert to ntfs' ... I had to convert via command prompt in DOS (or its equivalent in XP) OR ... did I miss the convert option somewhere?
nope
Disk Management will let you format a FAT32 drive as NTFS, but it won't convert unless you're talking about converting your data to empty space.
If you want to convert it needs to be done from the command line.
Nothing can stop me now, 'cause I don't care anymore.
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 16:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 13:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 16:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 09:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 11:17
