I just got a cheap DVD+RW recorder at the weekend to convert my old VHS collection to DVD, but I want to store them on DVD-R. Is there an easy way for me to transfer the data on the +RW to the -R? I just haven't had the chance to try doing anything on my PC yet, but if there is an easy way to do it, it would save reinventing the wheel. I have tried the search facility but can't seem to find anything. Even tried Google with no result.
Results 1 to 12 of 12
They have the same capacity, just do a straight DVD copy. I don't see why that wouldn't work.
Veni Vidi Vici -
Hello,
Ditto to what garrisonkw said. Just do a normal disc copy. Or if you want since its single layer use dvd decrypter and do iso read/write to make and burn an iso copy of it. Then delete the iso off the harddrive. THOUGH a on the fly copy will work if you have two dvd drives (though not always recommend from what I understand).
I rip it with DVD Decrypter, then place a DVD-R disc in my burner and burn it back with TempGenc DVD Author. Simple.
Interesting approach but do you really thinks it's that simple?Originally Posted by pepegot1You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Hello,Originally Posted by tompika
Yeah iso read/write in dvd decrypter itself is a LOT easier
(for single layer backups of course
That mean you wanna use DVD Decrypter and TMPGEnc DVD Author for a dual layer backup?Originally Posted by yoda313You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Hello,
No. If it's dual layer media you can iso read/write and burn a 1:1 with just dvd decrypter.Originally Posted by tompika
For transcoding a dvd9 to dvd5 I use dvdshrink and burn with roxio
All right then, first I thought Jedi Masters could do dual layer backups with that authoring program alone.
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Why bother?? I don't even have a dual layer burner! Just a trusty 4x single :P
canon10d; If you have TMPGEnc DVD Author you don't need to use other programs. You can use TDA to copy your DVD+RW to your harddrive, edit, create chapters, author and burn. The newest version of TMPGEnc DVD Author can do Dual Layer.
Thanks for all the replies. I think I will print this topic off and go through them.
Since posting yesterday, I decided to copy a VHS tape using the LP mode (3hrs/disk) whilst I was out in the evening. When I got back around midnight I did a very quick check of the disk in my PC using explorer and it shows up three folders. In the VIDEO_TS folder there were a number of files totalling over 7GB! How can this be? It is a 4.7GB disk!
DVD Backup - erroneous playback on dvd player althought perfect on the pc
By RedBolt in forum Authoring (DVD)Replies: 3Last Post: 12th Jun 2010, 00:00 -
How To Backup a DVD-Rom On a Blank DVD disc
By tealmarlin in forum Software PlayingReplies: 3Last Post: 8th Oct 2009, 13:13 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Unable to backup my dvd's with 740e and DVD decrypter
By sono in forum Newbie / General discussionsReplies: 12Last Post: 4th Sep 2007, 00:02
