  1. Hello
    I've been trying to use FFDshow VFW (latest alpha version released in Oct 2004) with VdubMod (V 1.5.10). The problem is that the codec doesn't appear anywhere in VDubMod. Is there a specific setting to enable so the VFW codec becomes available ? I had K-lite codec pack installed, could that be the problem ?
    Thanks for any help.
    Dec 2004
    Australia
    The problem is the NSIS script used for the installer, it uses a full path when it should use a short path variable. To fix it change the vidc.ffds registry entry from program files to progra~1.
    Newer versions use a vfw wrapper though so it isn't an issue any more.
  3. Thank you. I fixed the issue by installing one of your builds. I found it through the Doom9 forums and now it's all fixed.
    Thanks a lot
