I have a Toshiba SD-2715. I have played video cds that my brother made on there just fine, but when I try to burn video cds using the same program(nero) and the same disk(memorex cd-rw), the dvd player doesn't give me a disk error or anything, it just sits there and nothing happens. I cannot figure out what is going on. Is it possible that my burner is the problem? -Thanks in advance.
Does Nero give you an error message when you try to load your mpeg files in? And can it play in your computer?
I only dream in black & white...
MSN: paschendale@gmail.com -
i never tried playing it on my computer...I will try it thought, and as far as an error message...I have never gotten one in nero.
I can't play a DVD-RW on my Toshiba D R-400
By WC in forum DVD & Blu-ray RecordersReplies: 3Last Post: 24th Jul 2008, 12:23 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40
